41-300 stumped
Here is a link to the schematic. It looks like 3 e-caps of 25, 10 & 8 mfd. Not certain as to whether or not they are all in one can or multiple. Is the output transformer mounted on the speaker or chassis? Not apparent from the schematic.
Jerry
http://www.nostalgiaair.org/PagesByModel...013423.pdf
41-300 stumped - by dcastor - 06-22-2014, 11:30 AM
RE: 41-300 stumped - by jerryhawthorne - 06-22-2014, 02:14 PM
RE: 41-300 stumped - by dcastor - 06-22-2014, 02:45 PM
RE: 41-300 stumped - by jerryhawthorne - 06-22-2014, 03:51 PM
RE: 41-300 stumped - by murf - 06-22-2014, 04:34 PM
RE: 41-300 stumped - by murf - 06-23-2014, 07:21 PM
