116x Cabinet Substitution
Hi Brad
Your choices are limited:
116B - if you use a different speaker; the hum control rheostat may interfere with your ability to put it in a 116B tombstone cabinet, but it can be done.
I did this once. A 116X chassis in a 116B cabinet, with the smaller H (early version) or K (late version) speaker is a superb performer indeed!
Other choices:
660/665X
660/665L
That's all. It won't fit anything else without some modification to the cabinet.
116x Cabinet Substitution - by Guest - 08-27-2008, 08:07 PM
[No subject] - by Ron Ramirez - 08-27-2008, 10:40 PM
[No subject] - by Guest - 08-28-2008, 08:17 AM
There are currently 3746 online users. [Complete List]
» 1 Member(s) | 3745 Guest(s)
