41-300x
Crackling noise starts Immediately like I said before.
I will take a closer look tonight.
I will do as you suggested before and pull tubes one at a time while powered up and see if there is any change.
Will then flip it over and check for loose connections etc. around the rectifier and go from there.
Thanks again for your help,
murf
41-300x - by murf - 06-22-2014, 05:18 PM
RE: 41-300x - by morzh - 06-22-2014, 08:48 PM
RE: 41-300x - by murf - 06-22-2014, 09:14 PM
RE: 41-300x - by morzh - 06-22-2014, 09:17 PM
RE: 41-300x - by murf - 06-22-2014, 09:36 PM
RE: 41-300x - by morzh - 06-22-2014, 10:08 PM
RE: 41-300x - by murf - 06-23-2014, 06:42 AM
RE: 41-300x - by morzh - 06-23-2014, 12:02 PM
RE: 41-300x - by murf - 06-23-2014, 12:52 PM
RE: 41-300x - by morzh - 06-23-2014, 03:33 PM
RE: 41-300x - by murf - 06-23-2014, 04:45 PM
RE: 41-300x - by morzh - 06-23-2014, 05:04 PM
RE: 41-300x - by murf - 06-23-2014, 06:30 PM
RE: 41-300x - by murf - 06-23-2014, 07:23 PM
RE: 41-300x - by morzh - 06-23-2014, 07:26 PM
RE: 41-300x - by Eliot Ness - 06-23-2014, 07:29 PM
RE: 41-300x - by Arran - 06-24-2014, 10:07 PM
RE: 41-300x - by morzh - 06-24-2014, 10:15 PM
RE: 41-300x - by murf - 06-24-2014, 10:45 PM
RE: 41-300x - by bfrohwein - 06-25-2014, 02:32 PM
RE: 41-300x - by murf - 06-26-2014, 04:53 PM
RE: 41-300x - by vinzer - 06-26-2014, 05:06 PM
RE: 41-300x - by morzh - 06-26-2014, 07:06 PM
RE: 41-300x - by murf - 06-26-2014, 09:20 PM
RE: 41-300x - by morzh - 06-26-2014, 09:27 PM
RE: 41-300x - by murf - 06-26-2014, 10:09 PM
RE: 41-300x - by morzh - 06-26-2014, 10:22 PM
RE: 41-300x - by Arran - 06-26-2014, 11:33 PM
RE: 41-300x - by murf - 06-27-2014, 07:32 AM
RE: 41-300x - by morzh - 06-27-2014, 09:14 AM
RE: 41-300x - by bfrohwein - 06-27-2014, 05:11 PM
RE: 41-300x - by murf - 06-27-2014, 06:10 PM
RE: 41-300x - by morzh - 06-27-2014, 06:42 PM
RE: 41-300x - by murf - 06-28-2014, 07:49 PM
RE: 41-300x - by morzh - 06-28-2014, 08:15 PM
RE: 41-300x - by Arran - 06-28-2014, 10:23 PM
RE: 41-300x - by murf - 06-29-2014, 03:35 PM
RE: 41-300x - by morzh - 06-29-2014, 06:24 PM
RE: 41-300x - by murf - 06-29-2014, 08:45 PM
RE: 41-300x - by morzh - 06-29-2014, 09:19 PM
RE: 41-300x - by morzh - 06-30-2014, 06:27 PM
RE: 41-300x - by murf - 06-30-2014, 07:01 PM
RE: 41-300x - by Arran - 06-30-2014, 09:09 PM
RE: 41-300x - by Ron Ramirez - 06-30-2014, 09:32 PM
RE: 41-300x - by morzh - 06-30-2014, 10:35 PM
RE: 41-300x - by murf - 06-30-2014, 11:21 PM
RE: 41-300x - by murf - 07-01-2014, 09:03 PM
RE: 41-300x - by Arran - 07-01-2014, 09:23 PM
RE: 41-300x - by murf - 07-01-2014, 10:11 PM
RE: 41-300x - by morzh - 07-01-2014, 10:59 PM
RE: 41-300x - by murf - 07-02-2014, 06:38 AM
RE: 41-300x - by morzh - 07-02-2014, 09:28 AM
RE: 41-300x - by murf - 07-02-2014, 10:09 AM
RE: 41-300x - by morzh - 07-02-2014, 10:24 AM
RE: 41-300x - by murf - 07-05-2014, 07:33 PM
RE: 41-300x - by morzh - 07-05-2014, 07:45 PM
RE: 41-300x - by murf - 07-06-2014, 06:15 PM
RE: 41-300x - by morzh - 07-06-2014, 06:21 PM
RE: 41-300x - by murf - 07-07-2014, 01:11 PM
RE: 41-300x - by murf - 07-11-2014, 07:08 PM
RE: 41-300x - by murf - 07-11-2014, 08:37 PM
RE: 41-300x - by Art Hoch - 07-15-2014, 05:40 PM
RE: 41-300x - by murf - 07-15-2014, 06:23 PM
RE: 41-300x - by Arran - 07-16-2014, 06:20 AM
RE: 41-300x - by murf - 07-16-2014, 06:40 AM
RE: 41-300x - by Arran - 07-16-2014, 08:56 AM
RE: 41-300x - by murf - 07-16-2014, 10:19 AM
RE: 41-300x - by murf - 08-13-2014, 10:24 PM
RE: 41-300x - by bfrohwein - 08-23-2014, 09:05 PM
RE: 41-300x - by murf - 08-23-2014, 09:48 PM
There are currently 10471 online users. [Complete List]
» 2 Member(s) | 10469 Guest(s)
