Threads: 145
City: Elko,MN.
http://www.nostalgiaair.org/Resources/423/M0013423.htm
Crackling seems to be gone now, but I am getting no audio other than the very faint humm that you normally get.
Which tubes would control the audio end of it and which tubes control the reception?
murf
(This post was last modified: 06-24-2014, 10:34 PM by murf.)
RE: 41-300x - by murf - 06-23-2014, 07:23 PM
Users browsing this thread: 13 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10338 online users. [Complete List] » 1 Member(s) | 10337 Guest(s)
