  • 1 Vote(s) - 5 Average
Mikes 70 DONE
#47
Well, sorry guys, I could not make a good shot of it tonight. The radio is in a room with extremely high ceiling so indirect flash renders the radio almost black, and direct one obviously makes a contrast picture of it with a lot of reflections.
I will try to photograph it in the morning sun light as it is also indirect - my windows are facing north.
Mikes 70 DONE - by OldRestorer - 05-19-2014, 07:26 AM
RE: Mikes 70 - by OldRestorer - 05-19-2014, 07:29 AM
RE: Mikes 70 - by OldRestorer - 05-19-2014, 07:31 AM
RE: Mikes 70 - by OldRestorer - 05-19-2014, 07:36 AM
RE: Mikes 70 - by OldRestorer - 05-19-2014, 07:38 AM
RE: Mikes 70 - by OldRestorer - 05-19-2014, 07:39 AM
RE: Mikes 70 - by morzh - 05-19-2014, 09:57 AM
RE: Mikes 70 - by OldRestorer - 05-19-2014, 10:39 AM
RE: Mikes 70 - by OldRestorer - 05-19-2014, 11:43 AM
RE: Mikes 70 - by morzh - 05-19-2014, 12:21 PM
RE: Mikes 70 - by Jamie - 05-20-2014, 12:25 PM
RE: Mikes 70 - by OldRestorer - 05-20-2014, 12:51 PM
RE: Mikes 70 - by OldRestorer - 05-21-2014, 10:19 AM
RE: Mikes 70 - by morzh - 05-21-2014, 11:04 AM
RE: Mikes 70 - by OldRestorer - 05-21-2014, 11:22 AM
RE: Mikes 70 - by Steve Davis - 05-21-2014, 10:01 PM
RE: Mikes 70 - by OldRestorer - 05-22-2014, 07:13 AM
RE: Mikes 70 - by OldRestorer - 05-22-2014, 09:28 AM
RE: Mikes 70 - by radiohenry - 05-23-2014, 04:19 PM
RE: Mikes 70 - by OldRestorer - 05-24-2014, 07:09 PM
RE: Mikes 70 - by OldRestorer - 05-25-2014, 01:20 PM
RE: Mikes 70 - by OldRestorer - 05-26-2014, 12:59 PM
RE: Mikes 70 - by morzh - 05-26-2014, 06:08 PM
RE: Mikes 70 - by OldRestorer - 05-31-2014, 06:01 PM
RE: Mikes 70 - by PhilcoJohn - 06-03-2014, 08:03 AM
RE: Mikes 70 - by OldRestorer - 06-03-2014, 09:33 AM
RE: Mikes 70 - by morzh - 06-03-2014, 09:48 AM
RE: Mikes 70 - by OldRestorer - 06-04-2014, 03:33 PM
RE: Mikes 70 - by morzh - 06-04-2014, 03:46 PM
RE: Mikes 70 DONE - by OldRestorer - 06-05-2014, 03:12 PM
RE: Mikes 70 DONE - by morzh - 06-05-2014, 03:23 PM
RE: Mikes 70 DONE - by Warren - 06-05-2014, 03:42 PM
RE: Mikes 70 DONE - by OldRestorer - 06-05-2014, 03:50 PM
RE: Mikes 70 DONE - by morzh - 06-05-2014, 03:55 PM
RE: Mikes 70 DONE - by Eliot Ness - 06-05-2014, 04:24 PM
RE: Mikes 70 DONE - by Geoff - 06-05-2014, 04:47 PM
RE: Mikes 70 DONE - by Ron Ramirez - 06-05-2014, 05:18 PM
RE: Mikes 70 DONE - by morzh - 06-05-2014, 05:22 PM
RE: Mikes 70 DONE - by morzh - 06-05-2014, 05:33 PM
RE: Mikes 70 DONE - by Steve Davis - 06-05-2014, 05:40 PM
RE: Mikes 70 DONE - by morzh - 06-05-2014, 05:49 PM
RE: Mikes 70 DONE - by Eric Adams - 06-05-2014, 05:55 PM
RE: Mikes 70 DONE - by rocklandman - 06-06-2014, 08:30 PM
RE: Mikes 70 DONE - by radiohenry - 06-07-2014, 07:34 AM
RE: Mikes 70 DONE - by Steve Davis - 06-23-2014, 01:55 PM
RE: Mikes 70 DONE - by morzh - 06-23-2014, 03:34 PM
RE: Mikes 70 DONE - by morzh - 06-23-2014, 09:28 PM
RE: Mikes 70 DONE - by morzh - 07-06-2014, 06:08 PM
RE: Mikes 70 DONE - by OldRestorer - 07-06-2014, 07:29 PM
RE: Mikes 70 DONE - by morzh - 07-06-2014, 07:33 PM
RE: Mikes 70 DONE - by Steve Davis - 07-06-2014, 08:36 PM
RE: Mikes 70 DONE - by OldRestorer - 07-06-2014, 09:05 PM
RE: Mikes 70 DONE - by klondike98 - 07-07-2014, 10:11 AM
RE: Mikes 70 DONE - by morzh - 07-07-2014, 10:14 AM
RE: Mikes 70 DONE - by Steve Davis - 07-07-2014, 01:07 PM
