Chassis Rebuild
Very authentic moulded brown and black power cords can be had from Bob's Antique Radios:
http://www.radioantiques.com/supplies.html
Chassis Rebuild - by Robbie Roberts - 12-08-2005, 05:55 PM
[No subject] - by Jerry Huelsbeck - 12-09-2005, 11:48 AM
[No subject] - by Poston Drake - 12-09-2005, 11:53 AM
Thanks! - by Robbie Roberts - 12-09-2005, 03:08 PM
[No subject] - by Ron Ramirez - 12-09-2005, 03:52 PM
[No subject] - by Chuck Schwark - 12-09-2005, 04:13 PM
Wire Covering - by Robbie Roberts - 12-09-2005, 04:19 PM
[No subject] - by Ron Ramirez - 12-09-2005, 09:04 PM
[No subject] - by Poston Drake - 12-09-2005, 10:08 PM
[No subject] - by Ron Ramirez - 12-09-2005, 10:26 PM
Certainly Not! :) - by Robbie Roberts - 12-09-2005, 11:30 PM
Philco 91 Tuning Condenser
