41-300x
Noticed there are a couple bypass caps(1000 volt) on the 42 tube sockets.
Looks like cap numbers 76 and 79 on the schematic. I can't read the values as the copy is really blurry.
I tried to read the value off the caps, but they are buried and of course the number I need is on the underside. Don't want to remove them till I have the replacements.
I will have to get a copy from Chuck if I can't find a readable copy.
Can anyone tell me what the values of these 2 caps are?
Thanks for all the help guy's.
I wish my tech skills were even 1/2 of what you guy's have.
Unfortunately, my forte ended up being tool and die making, which I enjoy as well.
Does not help me much on this stuff though.
Just a hobby and I learn as I go.
Gotta have something to do in retirement.
If I can get a readable schematic, I can start checking voltages and see if the tranny is up to snuff.
Have a great evening,
murf
41-300x - by murf - 06-22-2014, 05:18 PM
RE: 41-300x - by morzh - 06-22-2014, 08:48 PM
RE: 41-300x - by murf - 06-22-2014, 09:14 PM
RE: 41-300x - by morzh - 06-22-2014, 09:17 PM
RE: 41-300x - by murf - 06-22-2014, 09:36 PM
RE: 41-300x - by morzh - 06-22-2014, 10:08 PM
RE: 41-300x - by murf - 06-23-2014, 06:42 AM
RE: 41-300x - by morzh - 06-23-2014, 12:02 PM
RE: 41-300x - by murf - 06-23-2014, 12:52 PM
RE: 41-300x - by morzh - 06-23-2014, 03:33 PM
RE: 41-300x - by murf - 06-23-2014, 04:45 PM
RE: 41-300x - by morzh - 06-23-2014, 05:04 PM
RE: 41-300x - by murf - 06-23-2014, 06:30 PM
RE: 41-300x - by murf - 06-23-2014, 07:23 PM
RE: 41-300x - by morzh - 06-23-2014, 07:26 PM
RE: 41-300x - by Eliot Ness - 06-23-2014, 07:29 PM
RE: 41-300x - by Arran - 06-24-2014, 10:07 PM
RE: 41-300x - by morzh - 06-24-2014, 10:15 PM
RE: 41-300x - by murf - 06-24-2014, 10:45 PM
RE: 41-300x - by bfrohwein - 06-25-2014, 02:32 PM
RE: 41-300x - by murf - 06-26-2014, 04:53 PM
RE: 41-300x - by vinzer - 06-26-2014, 05:06 PM
RE: 41-300x - by morzh - 06-26-2014, 07:06 PM
RE: 41-300x - by murf - 06-26-2014, 09:20 PM
RE: 41-300x - by morzh - 06-26-2014, 09:27 PM
RE: 41-300x - by murf - 06-26-2014, 10:09 PM
RE: 41-300x - by morzh - 06-26-2014, 10:22 PM
RE: 41-300x - by Arran - 06-26-2014, 11:33 PM
RE: 41-300x - by murf - 06-27-2014, 07:32 AM
RE: 41-300x - by morzh - 06-27-2014, 09:14 AM
RE: 41-300x - by bfrohwein - 06-27-2014, 05:11 PM
RE: 41-300x - by murf - 06-27-2014, 06:10 PM
RE: 41-300x - by morzh - 06-27-2014, 06:42 PM
RE: 41-300x - by murf - 06-28-2014, 07:49 PM
RE: 41-300x - by morzh - 06-28-2014, 08:15 PM
RE: 41-300x - by Arran - 06-28-2014, 10:23 PM
RE: 41-300x - by murf - 06-29-2014, 03:35 PM
RE: 41-300x - by morzh - 06-29-2014, 06:24 PM
RE: 41-300x - by murf - 06-29-2014, 08:45 PM
RE: 41-300x - by morzh - 06-29-2014, 09:19 PM
RE: 41-300x - by morzh - 06-30-2014, 06:27 PM
RE: 41-300x - by murf - 06-30-2014, 07:01 PM
RE: 41-300x - by Arran - 06-30-2014, 09:09 PM
RE: 41-300x - by Ron Ramirez - 06-30-2014, 09:32 PM
RE: 41-300x - by morzh - 06-30-2014, 10:35 PM
RE: 41-300x - by murf - 06-30-2014, 11:21 PM
RE: 41-300x - by murf - 07-01-2014, 09:03 PM
RE: 41-300x - by Arran - 07-01-2014, 09:23 PM
RE: 41-300x - by murf - 07-01-2014, 10:11 PM
RE: 41-300x - by morzh - 07-01-2014, 10:59 PM
RE: 41-300x - by murf - 07-02-2014, 06:38 AM
RE: 41-300x - by morzh - 07-02-2014, 09:28 AM
RE: 41-300x - by murf - 07-02-2014, 10:09 AM
RE: 41-300x - by morzh - 07-02-2014, 10:24 AM
RE: 41-300x - by murf - 07-05-2014, 07:33 PM
RE: 41-300x - by morzh - 07-05-2014, 07:45 PM
RE: 41-300x - by murf - 07-06-2014, 06:15 PM
RE: 41-300x - by morzh - 07-06-2014, 06:21 PM
RE: 41-300x - by murf - 07-07-2014, 01:11 PM
RE: 41-300x - by murf - 07-11-2014, 07:08 PM
RE: 41-300x - by murf - 07-11-2014, 08:37 PM
RE: 41-300x - by Art Hoch - 07-15-2014, 05:40 PM
RE: 41-300x - by murf - 07-15-2014, 06:23 PM
RE: 41-300x - by Arran - 07-16-2014, 06:20 AM
RE: 41-300x - by murf - 07-16-2014, 06:40 AM
RE: 41-300x - by Arran - 07-16-2014, 08:56 AM
RE: 41-300x - by murf - 07-16-2014, 10:19 AM
RE: 41-300x - by murf - 08-13-2014, 10:24 PM
RE: 41-300x - by bfrohwein - 08-23-2014, 09:05 PM
RE: 41-300x - by murf - 08-23-2014, 09:48 PM
Users browsing this thread: 13 Guest(s)
There are currently 10463 online users. [Complete List]
» 2 Member(s) | 10461 Guest(s)
