Just bought a FT-9 - anything to lookout for?
I had to learn nf cause all my multimeter's love reporting anything under .1 mfd as nf. I used to use this cheat sheet until I trained my brain to automatically move the decimal point around.
http://www.justradios.com/uFnFpF.html
