Threads: 145
City: Elko,MN.
Wondering if someone knows of a simple way of testing the output tranny on this radio?
Getting no audio other than a very slight humm.
Output tranny does get warm after being powered up for a 15 minutes or so.
murf
RE: 41-300x - by murf - 06-26-2014, 04:53 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10461 online users. [Complete List] » 2 Member(s) | 10459 Guest(s)
