E-cap rebuilding
My 70 has 2 Sprague caps which are mounted with a nut under the chassis.
Previously I had no problem neither with Mershons (having the caps atop), nor with Sprague ones mounted with a band where the seam would be hidden,
but this time it not the case.Any ideas? Thanks.
E-cap rebuilding - by fields 100 - 06-26-2014, 08:15 PM
RE: E-cap rebuilding - by morzh - 06-26-2014, 08:30 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 09:06 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:00 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 11:07 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:13 PM
RE: E-cap rebuilding - by Arran - 06-26-2014, 11:20 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 01:02 AM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 02:50 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 05:08 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 06:36 PM
RE: E-cap rebuilding - by Steve Davis - 06-27-2014, 09:37 PM
RE: E-cap rebuilding - by Arran - 06-27-2014, 11:04 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 11:40 PM
RE: E-cap rebuilding - by fields 100 - 06-28-2014, 07:05 PM
There are currently 8960 online users. [Complete List]
» 5 Member(s) | 8955 Guest(s)
AvatarAvatarAvatarAvatar
