Threads: 145
City: Elko,MN.
Well guy's, here is what I found.
Replaced the 42 tubes only and checked center tap on the output tranny to both plates of the 42 tubes and got 632 ohms on one and 1.48 k ohms on the other.
This was done with only the 42 tubes installed.
Look like new transformer is needed?
murf
(This post was last modified: 06-26-2014, 10:05 PM by murf.)
RE: 41-300x - by murf - 06-26-2014, 09:20 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10310 online users. [Complete List] » 1 Member(s) | 10309 Guest(s)
