Threads: 562
Murf
Are you sure you measured centertap to plates? Was the transformer unsoldered and soldered back again? Could it be you are measuring from one end to centertap and then to the other end?
PS. Which one is 43 tube?
RE: 41-300x - by morzh - 06-26-2014, 09:27 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9687 online users. [Complete List] » 3 Member(s) | 9684 Guest(s)
