E-cap rebuilding
Phlogiston
What you have just described actually makes me very happy. I can do a lot of things with a solder including forming and even body work (many years back, as a hobby).
Please tell me where do you cut the groove- in the middle or at the edge?
Your caps are mounted by clamps, mine are not, so it has to look 100% correct.
Also,how high is the bakelite? If it is below the groove, I can make and solder inner short copper nipple the the either side, put both halves together and then fill with solder prior to the filing and wire brushing. Thanks.
BTW, they are nickel plated with a groove on the bottom.
E-cap rebuilding - by fields 100 - 06-26-2014, 08:15 PM
RE: E-cap rebuilding - by morzh - 06-26-2014, 08:30 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 09:06 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:00 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 11:07 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:13 PM
RE: E-cap rebuilding - by Arran - 06-26-2014, 11:20 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 01:02 AM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 02:50 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 05:08 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 06:36 PM
RE: E-cap rebuilding - by Steve Davis - 06-27-2014, 09:37 PM
RE: E-cap rebuilding - by Arran - 06-27-2014, 11:04 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 11:40 PM
RE: E-cap rebuilding - by fields 100 - 06-28-2014, 07:05 PM
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 2806 online users. [Complete List]
» 2 Member(s) | 2804 Guest(s)
