E-cap rebuilding
I cut with a fine blade hack saw at the top of the crimp (grove). I even up the edges and lightly wire brush then use flux and an 800deg iron. Apply the solder like you were doing a weld. The color of the solder covers any exposed copper and matches the nickel nicely. If mine weren't already installed I would send a picture.
I use the 8mf caps spec. for 25hz transformer.
The Bakelite is well below this level.
E-cap rebuilding - by fields 100 - 06-26-2014, 08:15 PM
RE: E-cap rebuilding - by morzh - 06-26-2014, 08:30 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 09:06 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:00 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 11:07 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:13 PM
RE: E-cap rebuilding - by Arran - 06-26-2014, 11:20 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 01:02 AM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 02:50 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 05:08 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 06:36 PM
RE: E-cap rebuilding - by Steve Davis - 06-27-2014, 09:37 PM
RE: E-cap rebuilding - by Arran - 06-27-2014, 11:04 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 11:40 PM
RE: E-cap rebuilding - by fields 100 - 06-28-2014, 07:05 PM
There are currently 11424 online users. [Complete List]
» 2 Member(s) | 11422 Guest(s)
