E-cap rebuilding
With aluminum, indeed, there are not many choices. I have done the same thing as you, having PVC tubing inside, many times, but there always until now have been the clamps, so the seam could be hidden. Not this time around though.
BTW, I have somewhere the special flux and solder for the aluminum soldering but have not tried it yet. I know it is doable though.
Thanks.
E-cap rebuilding - by fields 100 - 06-26-2014, 08:15 PM
RE: E-cap rebuilding - by morzh - 06-26-2014, 08:30 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 09:06 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:00 PM
RE: E-cap rebuilding - by fields 100 - 06-26-2014, 11:07 PM
RE: E-cap rebuilding - by gregb - 06-26-2014, 11:13 PM
RE: E-cap rebuilding - by Arran - 06-26-2014, 11:20 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 01:02 AM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 02:50 PM
RE: E-cap rebuilding - by Phlogiston - 06-27-2014, 05:08 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 06:36 PM
RE: E-cap rebuilding - by Steve Davis - 06-27-2014, 09:37 PM
RE: E-cap rebuilding - by Arran - 06-27-2014, 11:04 PM
RE: E-cap rebuilding - by fields 100 - 06-27-2014, 11:40 PM
RE: E-cap rebuilding - by fields 100 - 06-28-2014, 07:05 PM
There are currently 4088 online users. [Complete List]
» 1 Member(s) | 4087 Guest(s)
