Philco 42-380X Reception problems, Need HELP!
Hi Dave
Hopefully, this is a lesson learned. Not so much about the 80 psi, but about the steel wool.
It is best to never use steel wool around electronic circuitry. Steel wool fibers are conductive. They can go anywhere and everywhere. They can get in between plates of your tuning condenser. They can get into trimmer condensers, IF transformers, you name it.
I suspect if the 80 psi had broken a lead wire, you would have found it by now.
Since you have reception on the preset pushbuttons, then chances are your set's IF transformers are OK. I would be looking for stray fibers between the plates of the tuning condenser, as Doug K. mentioned, and the contacts of the three tuning band pushbuttons. Heavy use of contact cleaner in conjunction with careful use of a toothbrush on the contacts of the pushbutton assembly is something you may try.
[No subject] - by Doug K. - 08-30-2008, 09:23 AM
[No subject] - by Ron Ramirez - 08-30-2008, 10:21 AM
[No subject] - by Steve Davis - 08-30-2008, 02:18 PM
[No subject] - by David B - 08-30-2008, 11:33 PM
[No subject] - by Doug K. - 08-31-2008, 08:43 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
Here we are. Boomer Sooner!  :lol: jrblasde — 09:40 PM
