Philco 45 tone control caps.
Arrran Wrote:I don't know why Philco insisted on using switches for their tone controls
Marketing, I think. When Philco introduced their (four position) tone control in the 1930 models (June 1930), they made a big deal in their advertising of their "four point tone control...Brilliant...Bright...Mellow...Deep."
Quote:The switch gives you three ranges bass, medium and treble, and the pot allows you to adjust it anywhere in between. Did I mention that this was also a five tube console, shame on you Philco!
Icon_lol
Philco 45 tone control caps. - by morzh - 06-28-2014, 06:59 PM
RE: Philco 45 tone control caps. - by morzh - 06-28-2014, 07:02 PM
RE: Philco 45 tone control caps. - by Arran - 06-28-2014, 11:11 PM
RE: Philco 45 tone control caps. - by morzh - 06-29-2014, 12:02 AM
RE: Philco 45 tone control caps. - by Arran - 06-29-2014, 12:29 AM
RE: Philco 45 tone control caps. - by Ron Ramirez - 06-29-2014, 08:34 AM
There are currently 9694 online users. [Complete List]
» 1 Member(s) | 9693 Guest(s)
