  • 1 Vote(s) - 5 Average
Fogged clear
Which tells me that the milkiness then is purely surface phenomenon, the top surface forming into something not as smooth as it is supposed to be and the No Blush makes these wrinkles disappear. Otherwise it wouldn't help, were it structural and not surface.
Good to know.
Fogged clear - by Eric Adams - 06-29-2014, 10:17 PM
RE: Fogged clear - by Steve Davis - 06-29-2014, 10:56 PM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 05:38 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 08:49 AM
RE: Fogged clear - by morzh - 06-30-2014, 08:57 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 09:01 AM
RE: Fogged clear - by morzh - 06-30-2014, 10:54 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 11:33 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 11:43 AM
RE: Fogged clear - by bfrohwein - 06-30-2014, 12:21 PM
RE: Fogged clear - by Steve Davis - 06-30-2014, 01:19 PM
RE: Fogged clear - by Chuck Schwark - 06-30-2014, 01:45 PM
RE: Fogged clear - by Bob Andersen - 06-30-2014, 09:22 PM
RE: Fogged clear - by jerryhawthorne - 06-30-2014, 10:48 PM
RE: Fogged clear - by TA Forbes - 07-01-2014, 01:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 02:13 PM
RE: Fogged clear - by Warren - 07-01-2014, 04:09 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 04:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 05:47 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 06:41 PM
RE: Fogged clear - by Arran - 07-02-2014, 12:09 AM
RE: Fogged clear - by Bob Andersen - 07-02-2014, 12:56 AM
RE: Fogged clear - by jerryhawthorne - 07-02-2014, 01:05 AM
There are currently 10823 online users. [Complete List]
» 3 Member(s) | 10820 Guest(s)
