  • 1 Vote(s) - 5 Average
Fogged clear
wow.. I usually use the ultraflo when it's more humid to avoid blushing. how humid was it? Mohawk recommends not to go above 65% or below 65 degrees. however, Bob Anderson did a video on one of his tombstones. seemed that around 55-60 the lacquer stayed fluid just a little longer and flowed out better.
that super blush retarder is wonderful stuff. just the lightest misting is needed. it disappears before your eyes like a TV commercial
Fogged clear - by Eric Adams - 06-29-2014, 10:17 PM
RE: Fogged clear - by Steve Davis - 06-29-2014, 10:56 PM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 05:38 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 08:49 AM
RE: Fogged clear - by morzh - 06-30-2014, 08:57 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 09:01 AM
RE: Fogged clear - by morzh - 06-30-2014, 10:54 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 11:33 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 11:43 AM
RE: Fogged clear - by bfrohwein - 06-30-2014, 12:21 PM
RE: Fogged clear - by Steve Davis - 06-30-2014, 01:19 PM
RE: Fogged clear - by Chuck Schwark - 06-30-2014, 01:45 PM
RE: Fogged clear - by Bob Andersen - 06-30-2014, 09:22 PM
RE: Fogged clear - by jerryhawthorne - 06-30-2014, 10:48 PM
RE: Fogged clear - by TA Forbes - 07-01-2014, 01:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 02:13 PM
RE: Fogged clear - by Warren - 07-01-2014, 04:09 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 04:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 05:47 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 06:41 PM
RE: Fogged clear - by Arran - 07-02-2014, 12:09 AM
RE: Fogged clear - by Bob Andersen - 07-02-2014, 12:56 AM
RE: Fogged clear - by jerryhawthorne - 07-02-2014, 01:05 AM
