Philco 42-400 With Add On Fm Adapter
Looks like the Hallicrafters FM converter to convert the pre-war FM band to the modern FM band.
[Image: http://www.somerset.net/arm/radio_pictur...erters.jpg]
[Image: http://userpages.bright.net/~geary/fm/mfgfmconv.jpg]
Sean
WØKPX
RE: Philco 42-400 With Add On Fm Adapter - by Sean - 06-30-2014, 04:41 PM
The speaker table error?
Philco 70 antenna lead
