Do not operate the set any more than necessary to make quick voltage measurements. Obviously you have a major B+ short to ground somewhere; now it is up to you to find it using professional troubleshooting techniques. The guys here can help...
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10324 online users. [Complete List] » 1 Member(s) | 10323 Guest(s)
