Chassis Rebuild
Ron,
This has turned into an interesting thread, I have learned a lot. I had pretty much concluded that 1939 and later models originally used rubber line cords. But I had assumed that 1937 and 1938 models used cloth-covered as in earlier years, and that those I have seen or serviced with rubber cords were probably replacements. Now I know better, thanks for the info.
Chuck,
I appreciated the link to Bob's Old Radios as a source for period-styled line cords.
Poston
Chassis Rebuild - by Robbie Roberts - 12-08-2005, 05:55 PM
[No subject] - by Jerry Huelsbeck - 12-09-2005, 11:48 AM
[No subject] - by Poston Drake - 12-09-2005, 11:53 AM
Thanks! - by Robbie Roberts - 12-09-2005, 03:08 PM
[No subject] - by Ron Ramirez - 12-09-2005, 03:52 PM
[No subject] - by Chuck Schwark - 12-09-2005, 04:13 PM
Wire Covering - by Robbie Roberts - 12-09-2005, 04:19 PM
[No subject] - by Ron Ramirez - 12-09-2005, 09:04 PM
[No subject] - by Poston Drake - 12-09-2005, 10:08 PM
[No subject] - by Ron Ramirez - 12-09-2005, 10:26 PM
Certainly Not! :) - by Robbie Roberts - 12-09-2005, 11:30 PM
