  • 1 Vote(s) - 5 Average
Fogged clear
The brushing lacquer is nitrocellulose lacquer also. Here is the MSDS on the aerosol http://www.deftfinishes.com/trade/sites/...172010.pdf and the brushing lacquer http://www.deftfinishes.com/trade/sites/...6-2012.pdf
The reason they say not to thin and spray the brushing lacquer is because of the VOC content, it is just an EPA thing. Actually, thinning and spraying brushing lacquer works very well. I do it all the time.
M R Radios   C M Tubes
Fogged clear - by Eric Adams - 06-29-2014, 10:17 PM
RE: Fogged clear - by Steve Davis - 06-29-2014, 10:56 PM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 05:38 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 08:49 AM
RE: Fogged clear - by morzh - 06-30-2014, 08:57 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 09:01 AM
RE: Fogged clear - by morzh - 06-30-2014, 10:54 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 11:33 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 11:43 AM
RE: Fogged clear - by bfrohwein - 06-30-2014, 12:21 PM
RE: Fogged clear - by Steve Davis - 06-30-2014, 01:19 PM
RE: Fogged clear - by Chuck Schwark - 06-30-2014, 01:45 PM
RE: Fogged clear - by Bob Andersen - 06-30-2014, 09:22 PM
RE: Fogged clear - by jerryhawthorne - 06-30-2014, 10:48 PM
RE: Fogged clear - by TA Forbes - 07-01-2014, 01:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 02:13 PM
RE: Fogged clear - by Warren - 07-01-2014, 04:09 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 04:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 05:47 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 06:41 PM
RE: Fogged clear - by Arran - 07-02-2014, 12:09 AM
RE: Fogged clear - by Bob Andersen - 07-02-2014, 12:56 AM
RE: Fogged clear - by jerryhawthorne - 07-02-2014, 01:05 AM
