  • 1 Vote(s) - 5 Average
Fogged clear
+1 on Steve's comments on Deft, the reducing when spraying it through a gun has to be right. Not enough and if won't flow out smooth with a good wet coat. Too much and spraying on a vertical surface (which I don't like to do) and runs.
Jerry
Fogged clear - by Eric Adams - 06-29-2014, 10:17 PM
RE: Fogged clear - by Steve Davis - 06-29-2014, 10:56 PM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 05:38 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 08:49 AM
RE: Fogged clear - by morzh - 06-30-2014, 08:57 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 09:01 AM
RE: Fogged clear - by morzh - 06-30-2014, 10:54 AM
RE: Fogged clear - by Ron Ramirez - 06-30-2014, 11:33 AM
RE: Fogged clear - by Eric Adams - 06-30-2014, 11:43 AM
RE: Fogged clear - by bfrohwein - 06-30-2014, 12:21 PM
RE: Fogged clear - by Steve Davis - 06-30-2014, 01:19 PM
RE: Fogged clear - by Chuck Schwark - 06-30-2014, 01:45 PM
RE: Fogged clear - by Bob Andersen - 06-30-2014, 09:22 PM
RE: Fogged clear - by jerryhawthorne - 06-30-2014, 10:48 PM
RE: Fogged clear - by TA Forbes - 07-01-2014, 01:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 02:13 PM
RE: Fogged clear - by Warren - 07-01-2014, 04:09 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 04:21 PM
RE: Fogged clear - by Bob Andersen - 07-01-2014, 05:47 PM
RE: Fogged clear - by Steve Davis - 07-01-2014, 06:41 PM
RE: Fogged clear - by Arran - 07-02-2014, 12:09 AM
RE: Fogged clear - by Bob Andersen - 07-02-2014, 12:56 AM
RE: Fogged clear - by jerryhawthorne - 07-02-2014, 01:05 AM
There are currently 9078 online users. [Complete List]
» 1 Member(s) | 9077 Guest(s)
