Stromberg Carlson 225-H restoration chronicles
Well,
I have been a bit busy and haven't touched a radio in 3 weeks or so but I actually got time to work today. The 41-KR is shelved for now and I am starting on a Stromberg cabinet. The cabinet is pretty solid and is clean minus a badly scraped corner, some finish issues, a missing veneer chunk or 2 and a tiny bit of play in the cabinet.
Stromberg Carlson 225-H restoration chronicles - by OldRestorer - 07-02-2014, 08:44 PM
