Philco 46-1203, radio doesn't work.
Neal:
You'll find a resistance & voltage chart for the 46-1203 at nostalgiair and http://www.oldtech.net/philco . I got my 1203 running fine and shipped it to a friend who bought it for her mother and had it shipped to me for restoration. I had replaced this 1203's capacitors also, but did it one at time, checking after each part replacement to see if the radio still worked.
Kevin
Philco 46-1203, radio doesn't work. - by Guest - 02-04-2008, 09:47 PM
[No subject] - by TonyJSenior - 02-05-2008, 06:07 PM
[No subject] - by TonyJSenior - 02-05-2008, 07:48 PM
[No subject] - by Guest - 02-06-2008, 04:28 AM
[No subject] - by TonyJSenior - 02-06-2008, 08:26 AM
[No subject] - by Guest - 02-06-2008, 01:14 PM
[No subject] - by TonyJSenior - 02-06-2008, 01:23 PM
46-1203 volume control - by Guest - 06-19-2008, 11:44 AM
46-1203 volume control - by Guest - 06-19-2008, 11:59 AM
[No subject] - by gary rabbitt - 06-20-2008, 02:06 PM
Re: Philco 46-1203, radio doesn't work. - by Guest - 07-19-2008, 03:38 AM
Re: 46-1203 volume control - by Guest - 07-19-2008, 03:43 AM
philco 46-1203 - by Guest - 08-30-2008, 12:03 AM
[No subject] - by BDM - 08-30-2008, 01:13 AM
Re: Philco 46-1203, radio doesn't work. - by Guest - 09-04-2008, 12:14 AM
Re: Philco 46-1203, radio doesn't work. - by Guest - 09-04-2008, 02:09 AM
