Original Philco 20 Cabinet Colors
I saw two varieties of colours in unrestored 20s - the mahogany (or whatever that reddish is) and walnut (or whatever that dark-yellowish honey tint is).
Original Philco 20 Cabinet Colors - by Phlogiston - 07-03-2014, 02:33 AM
RE: Original Philco 20 Cabinet Colors - by morzh - 07-03-2014, 09:47 AM
RE: Original Philco 20 Cabinet Colors - by Arran - 07-03-2014, 11:59 PM
