Original Philco 20 Cabinet Colors
Yes. In particular I was wondering about the edge shading.
Taking note that the "deluxe" version is shaded around the edges of the arch.
Original Philco 20 Cabinet Colors - by Phlogiston - 07-03-2014, 02:33 AM
RE: Original Philco 20 Cabinet Colors - by morzh - 07-03-2014, 09:47 AM
RE: Original Philco 20 Cabinet Colors - by Phlogiston - 07-03-2014, 10:56 AM
RE: Original Philco 20 Cabinet Colors - by Arran - 07-03-2014, 11:59 PM
There are currently 3544 online users. [Complete List]
» 1 Member(s) | 3543 Guest(s)
