Chassis Rebuild
Bob of Bob's Antique Radios is a great guy. I try to buy at least something from him whenever I attend a Radiofest meet. And, as Chuck pointed out, he has a website and sells caps, cords and other useful items via mail and Internet.
Chassis Rebuild - by Robbie Roberts - 12-08-2005, 05:55 PM
[No subject] - by Jerry Huelsbeck - 12-09-2005, 11:48 AM
[No subject] - by Poston Drake - 12-09-2005, 11:53 AM
Thanks! - by Robbie Roberts - 12-09-2005, 03:08 PM
[No subject] - by Ron Ramirez - 12-09-2005, 03:52 PM
[No subject] - by Chuck Schwark - 12-09-2005, 04:13 PM
Wire Covering - by Robbie Roberts - 12-09-2005, 04:19 PM
[No subject] - by Ron Ramirez - 12-09-2005, 09:04 PM
[No subject] - by Poston Drake - 12-09-2005, 10:08 PM
[No subject] - by Ron Ramirez - 12-09-2005, 10:26 PM
Certainly Not! :) - by Robbie Roberts - 12-09-2005, 11:30 PM
Philco 91 Tuning Condenser
There are currently 10151 online users. [Complete List]
» 3 Member(s) | 10148 Guest(s)
