46-1226 veneer replacement
Hello all! I am having to replace the upper middle section of veneer on this 46-1226 Philco and need to know what type of veneer -Walnut? Seems too light for walnut. (The middle where the escutcheon sits from back of radio to trim over the RP door). Thank you!
Mark
46-1226 veneer replacement - by markskala - 07-05-2014, 07:00 PM
RE: 46-1228 veneer replacement - by OldRestorer - 07-05-2014, 07:42 PM
RE: 46-1228 veneer replacement - by markskala - 07-05-2014, 08:32 PM
RE: 46-1228 veneer replacement - by Arran - 07-06-2014, 02:09 AM
RE: 46-1228 veneer replacement - by markskala - 07-06-2014, 07:16 AM
RE: 46-1228 veneer replacement - by Arran - 07-08-2014, 06:04 AM
RE: 46-1228 veneer replacement - by markskala - 07-08-2014, 08:36 PM
RE: 46-1226 veneer replacement - by Marsupial - 07-09-2014, 01:23 PM
There are currently 9844 online users. [Complete List]
» 1 Member(s) | 9843 Guest(s)
