116B cabinet refinish done
That looks great Brian. Where is Barry located? I can't find anything searching for recommended re-finishers on this forum. Did you send the cabinet?
I'm not sure I would dare mail my 90 across country, but I would love to see it's original beauty restored. Anyone know of someone with a good rep near Mpls?
How about a ballpark estimate for a cabinet with no veneer issues, only a few minor cracks in the frame?
Thanks
116B cabinet refinish done - by BDM - 09-04-2008, 10:14 PM
Re: 116B cabinet refinish done - by etech - 09-04-2008, 10:46 PM
Re: 116B cabinet refinish done - by Ron Ramirez - 09-04-2008, 11:22 PM
Re: 116B cabinet refinish done - by Uffda - 09-05-2008, 12:01 AM
Re: 116B cabinet refinish done - by BDM - 09-05-2008, 12:11 AM
Re: 116B cabinet refinish done - by Ron Ramirez - 09-05-2008, 12:12 AM
Re: 116B cabinet refinish done - by Uffda - 09-05-2008, 12:42 AM
Re: 116B cabinet refinish done - by Texasrocker - 09-06-2008, 02:11 AM
Re: 116B cabinet refinish done - by Ron Ramirez - 09-06-2008, 09:25 AM
There are currently 8871 online users. [Complete List]
» 2 Member(s) | 8869 Guest(s)
