Philco 41-255, 42-1008 Wattage Consumption
On the 42-1008, rough calculations show between 50-60 watts. That's not a very powerful set of tubes.
You might want to invest in one of those cheap "Kill A Watt" digital boxes that show line volts, current drain, wattage, and watt hours; they cost less than $25. They can be used very effectively with a variac to monitor current and voltage. Mine has been used extensively for locating household current drain as a solar electric system comes on-line.
Pete AI2V
Re: Philco 41-255, 42-1008 Wattage Consumption - by AI2V - 09-05-2008, 10:44 AM
There are currently 7031 online users. [Complete List]
» 1 Member(s) | 7030 Guest(s)
