Band switch Model 60
Morzh, no I tried to get a signal thru but a bit unsure of the proper procedure. I attached SG to antenna and tried to send thru a signal in the SW band frequency range. No signal made it thru...and to my knowledge there is no trimmer or padder to adjust either. Based on my oscope reading, the frequencies are ok as shown in the SW sine wave output. So...still confusing to me!!!! Thanks for help.
Band switch Model 60 - by sjhs1962 - 07-06-2014, 10:27 AM
RE: Band switch Model 60 - by sjhs1962 - 07-06-2014, 12:36 PM
RE: Band switch Model 60 - by morzh - 07-06-2014, 02:16 PM
RE: Band switch Model 60 - by sjhs1962 - 07-06-2014, 07:12 PM
RE: Band switch Model 60 - by sjhs1962 - 07-06-2014, 09:35 PM
RE: Band switch Model 60 - by morzh - 07-06-2014, 10:02 PM
RE: Band switch Model 60 - by sjhs1962 - 07-07-2014, 05:30 PM
RE: Band switch Model 60 - by sjhs1962 - 07-11-2014, 08:55 PM
RE: Band switch Model 60 - by codefox1 - 07-13-2014, 01:21 PM
RE: Band switch Model 60 - by sjhs1962 - 07-25-2014, 11:50 AM
RE: Band switch Model 60 - by codefox1 - 07-25-2014, 12:16 PM
RE: Band switch Model 60 - by sjhs1962 - 08-06-2014, 09:05 PM
RE: Band switch Model 60 - by Steve Davis - 08-06-2014, 10:12 PM
RE: Band switch Model 60 - by sjhs1962 - 08-07-2014, 11:26 AM
RE: Band switch Model 60 - by sjhs1962 - 08-11-2014, 08:25 PM
RE: Band switch Model 60 - by sjhs1962 - 08-12-2014, 04:41 PM
RE: Band switch Model 60 - by morzh - 08-12-2014, 05:17 PM
RE: Band switch Model 60 - by Steve Davis - 08-12-2014, 06:05 PM
RE: Band switch Model 60 - by sjhs1962 - 08-14-2014, 12:07 PM
RE: Band switch Model 60 - by morzh - 08-14-2014, 01:32 PM
RE: Band switch Model 60 - by sjhs1962 - 08-16-2014, 04:56 PM
RE: Band switch Model 60 - by morzh - 08-16-2014, 05:15 PM
RE: Band switch Model 60 - by winston763 - 08-20-2014, 08:49 AM
RE: Band switch Model 60 - by sjhs1962 - 08-20-2014, 09:22 PM
RE: Band switch Model 60 - by morzh - 08-20-2014, 09:40 PM
RE: Band switch Model 60 - by ccomer1955 - 08-20-2014, 11:21 PM
RE: Band switch Model 60 - by winston763 - 08-20-2014, 11:27 PM
RE: Band switch Model 60 - by morzh - 08-21-2014, 07:09 AM
RE: Band switch Model 60 - by winston763 - 08-23-2014, 01:49 AM
RE: Band switch Model 60 - by morzh - 08-23-2014, 11:28 AM
RE: Band switch Model 60 - by winston763 - 08-24-2014, 01:01 AM
RE: Band switch Model 60 - by sjhs1962 - 08-26-2014, 07:21 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
There are currently 2707 online users. [Complete List]
» 5 Member(s) | 2702 Guest(s)
AvatarAvatarAvatarAvatar
