looking for a glass front for this philco the restoration people who cleans up after a house fire broke it so if I can't find one how much should I get from them? thanks Greg.
46-1226 - by Guest - 09-05-2008, 08:42 PM
Re: 46-1226 - by Guest - 10-01-2010, 09:07 AM
There are currently 8522 online users. [Complete List]
» 1 Member(s) | 8521 Guest(s)
