  • 1 Vote(s) - 1 Average
Bel Geddes what?
Thanks for chiming in Ron. I figured someone did a chassis switch a long time ago. I was thinking of trying to find a good original model 112 to stick in this cabinet. My question is about the speaker.
How similar are the speakers between the 96, 111, and 112. Would I need to change anything in the circuit if I were to put a chassis 112 in this set. It appears the speaker connection is the four pin type, and most definaty a Philco with the labeling on the pin connector and speaker assembly. Will the set sound any diffrent depending on which chassis is used? Or are all the speaker values the same for these three chassis. I dont really have a clue when it comes to speakers, still a newbe. I cant seem to find any information on the speakers either, only that the 96-A schematic states: Speaker plug and socket connections (Early models 13,000W, Late models 33,000 W). As you can tell I am still a little lost.
Thanks for the help
Jon
Bel Geddes what? - by Philco281989 - 07-07-2014, 05:15 PM
RE: Bel Geddes what? - by Jayce - 07-08-2014, 12:03 AM
RE: Bel Geddes what? - by y2kbruce - 07-08-2014, 07:01 AM
RE: Bel Geddes what? - by Philco281989 - 07-08-2014, 09:35 AM
RE: Bel Geddes what? - by Ron Ramirez - 07-08-2014, 11:50 AM
RE: Bel Geddes what? - by Philco281989 - 07-08-2014, 06:54 PM
RE: Bel Geddes what? - by Arran - 07-10-2014, 08:41 AM
RE: Bel Geddes what? - by Philco281989 - 07-10-2014, 11:15 AM
RE: Bel Geddes what? - by Arran - 07-11-2014, 01:26 PM
RE: Bel Geddes what? - by Philco281989 - 07-12-2014, 04:44 PM
RE: Bel Geddes what? - by Arran - 07-13-2014, 01:29 PM
There are currently 3517 online users. [Complete List]
» 3 Member(s) | 3514 Guest(s)
