Philco 16B 2meg volume control tone tap specs?
Hi Dave
This change was made during production of Model 16 Codes 121, 122 & 123 (the 5-band models). The newer control is part no. 33-5022, 2 meg., tapped at 400K.
The same control was used in Model 16 Codes 125, 126 & 127 (the 4-band models), and both tombstone and console versions of Model 116.
[No subject] - by Ron Ramirez - 12-10-2005, 11:53 AM
Restoring Philco 96
There are currently 7568 online users. [Complete List]
» 2 Member(s) | 7566 Guest(s)
