1931 Grandfather Clock/radio completed!
Water pistol, or a newspaper usually dissuades them from such things. I've never had a cat that like to chase mechanical things nor climb after them. The good news is that I think that these sets used the same grille cloth as a model 70/90 and that is available again.
1931 Grandfather Clock/radio completed! - by AI2V - 07-08-2014, 11:38 AM
RE: 1931 Grandfather Clock/radio completed! - by Arran - 07-10-2014, 08:50 AM
There are currently 6395 online users. [Complete List]
» 3 Member(s) | 6392 Guest(s)
