Recently acquired 116X pic
I'll probably dig in later in the year. Probably well into fall. I have a few others, including the 116B chassis I need to finish. But I'll post the results or problems I encounter.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Recently acquired 116X pic - by BDM - 09-05-2008, 11:14 PM
Re: Recently acquired 116X pic - by etech - 09-05-2008, 11:21 PM
Re: Recently acquired 116X pic - by 49Stude63 - 09-06-2008, 10:17 AM
Re: Recently acquired 116X pic - by BDM - 09-07-2008, 02:04 AM
Re: Recently acquired 116X pic - by Chuck Schwark - 09-07-2008, 10:38 PM
