Knight 600A tester
Without a doubt the TV-7 is a much better tester than your present tester but at a much higher cost. Be carefully buying one because they, just like yours, need to be properly restored and calibrated to provide the expected results.
Gregb
Knight 600A tester - by fields 100 - 07-08-2014, 08:53 AM
RE: Knight 600A tester - by Phlogiston - 07-08-2014, 09:51 AM
RE: Knight 600A tester - by morzh - 07-08-2014, 10:06 AM
RE: Knight 600A tester - by fields 100 - 07-08-2014, 12:07 PM
RE: Knight 600A tester - by gregb - 07-08-2014, 01:04 PM
RE: Knight 600A tester - by fields 100 - 07-08-2014, 01:54 PM
RE: Knight 600A tester - by morzh - 07-08-2014, 02:04 PM
RE: Knight 600A tester - by gregb - 07-08-2014, 02:35 PM
RE: Knight 600A tester - by OldRestorer - 07-08-2014, 03:59 PM
RE: Knight 600A tester - by fields 100 - 07-08-2014, 05:12 PM
RE: Knight 600A tester - by gregb - 07-08-2014, 05:18 PM
RE: Knight 600A tester - by fields 100 - 07-08-2014, 08:02 PM
RE: Knight 600A tester - by gregb - 07-08-2014, 08:41 PM
RE: Knight 600A tester - by fields 100 - 07-08-2014, 10:33 PM
RE: Knight 600A tester - by codefox1 - 07-09-2014, 11:41 PM
RE: Knight 600A tester - by fields 100 - 07-10-2014, 09:23 AM
RE: Knight 600A tester - by gregb - 07-10-2014, 10:07 AM
RE: Knight 600A tester - by codefox1 - 07-13-2014, 12:43 PM
RE: Knight 600A tester - by morzh - 07-13-2014, 02:06 PM
RE: Knight 600A tester - by cantonkid - 02-07-2017, 09:12 PM
RE: Knight 600A tester - by sam - 02-08-2017, 02:42 PM
RE: Knight 600A tester - by cantonkid - 02-09-2017, 11:34 AM
RE: Knight 600A tester - by cantonkid - 02-09-2017, 05:33 PM
RE: Knight 600A tester - by Eliot Ness - 02-21-2017, 10:05 AM
Eico 232 VTVM Schematic
There are currently 5318 online users. [Complete List]
» 1 Member(s) | 5317 Guest(s)
