Repro. escutcheons
I approached Larry Bordonaro, and Ed (Blacksmith) about making these escutcheons. Neither felt these escutcheons would sell well enough to justify making the molds, not to mention the high start-up costs involved.
It's too bad. Personally, I feel the popularity of the 41-226T, called "The Sled" by many collectors, would alone justify someone tooling up to make the escutcheon available.
All someone has to do is copy the 47-205 or 48-206 escutcheon - it is the same pattern, and made of an improved non-shrinking plastic. But the 47-205/48-206 escutcheon is ivory, and a marbleized brown is needed for some models, and a very dark brown for the 41-226T.
Repro. escutcheons - by don'tdomelikethat - 09-16-2008, 04:03 PM
Re: Repro. escutcheons - by Ron Ramirez - 09-16-2008, 05:56 PM
Re: Repro. escutcheons - by Guest - 09-17-2008, 10:58 AM
Re: Repro. escutcheons - by Ron Ramirez - 09-17-2008, 06:40 PM
Eico 232 VTVM Schematic
There are currently 9970 online users. [Complete List]
» 1 Member(s) | 9969 Guest(s)
