42-1011 chassis issues
David
At least some of those wax caps are a hazard that can take your power supply out.
Some might not matter much, but all of them are bad and will check out as 3-4 times the nominal value.
I think there is not one person here who would not tell you to change them.
But if you are really trying to do as little as possible, at least change caps directly expised to B+.
# 76 and 85 for example.
However even if it works, you are likely screwing DC biasing of the tube as your DC blocking caps are likely leaking.
This is one case where it is not a waste of time.
42-1011 chassis issues - by davidff - 07-07-2014, 07:55 AM
RE: 42-1011 chassis issues - by morzh - 07-07-2014, 08:59 AM
RE: 42-1011 chassis issues - by davidff - 07-07-2014, 09:33 AM
RE: 42-1011 chassis issues - by morzh - 07-07-2014, 09:37 AM
RE: 42-1011 chassis issues - by davidff - 07-07-2014, 09:48 AM
RE: 42-1011 chassis issues - by morzh - 07-07-2014, 10:00 AM
RE: 42-1011 chassis issues - by morzh - 07-07-2014, 10:06 AM
RE: 42-1011 chassis issues - by davidff - 07-09-2014, 07:43 AM
RE: 42-1011 chassis issues - by Ron Ramirez - 07-09-2014, 04:29 PM
RE: 42-1011 chassis issues - by davidff - 07-11-2014, 08:36 AM
RE: 42-1011 chassis issues - by Arran - 07-11-2014, 01:11 PM
RE: 42-1011 chassis issues - by Warren - 07-11-2014, 01:19 PM
RE: 42-1011 chassis issues - by morzh - 07-11-2014, 03:02 PM
RE: 42-1011 chassis issues - by davidff - 07-14-2014, 02:08 PM
RE: 42-1011 chassis issues - by morzh - 07-14-2014, 02:56 PM
RE: 42-1011 chassis issues - by davidff - 07-15-2014, 08:00 AM
RE: 42-1011 chassis issues - by morzh - 07-15-2014, 08:59 AM
RE: 42-1011 chassis issues - by TA Forbes - 07-15-2014, 09:03 AM
New member
Philco 630csx power cord
New member
There are currently 4069 online users. [Complete List]
» 1 Member(s) | 4068 Guest(s)
