Brunswick Panatrope with Radio S31
Tube lineup looks like 4- 24's, a 27, an 80, 2- 45's and a "regulator" tube. I got a deal on a pair of 45's last fall on the bay for my Philco 95 Lowboy...I'll just keep watching. Have to figure out what the regulator tube is.
RE: Brunswick Panatrope with Radio S31 - by morzh - 07-11-2014, 05:14 PM
RE: Brunswick Panatrope with Radio S31 - by Groundhog74 - 07-11-2014, 05:56 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-13-2014, 08:46 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-14-2014, 10:37 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-16-2014, 10:45 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-16-2014, 12:21 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-17-2014, 12:51 PM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:39 AM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:55 AM
There are currently 2537 online users. [Complete List]
» 2 Member(s) | 2535 Guest(s)
