Wire wound resistor
Wattage is always U-square over R.
You know the voltages at the taps of each section and each section's resstance, so the difference of the voltage between any two pins (or the same measured directly as voltage between pins) squared over its resistance will be your disipation, then use a factor of at least two.
Wire wound resistor - by fields 100 - 07-11-2014, 08:52 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 09:16 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 10:01 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:11 PM
RE: Wire wound resistor - by Warren - 07-11-2014, 10:50 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:56 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 11:00 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:03 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:05 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:12 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:20 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:16 AM
RE: Wire wound resistor - by GarySP - 07-12-2014, 09:30 AM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:46 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:01 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 10:37 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:47 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 11:01 PM
RE: Wire wound resistor - by codefox1 - 07-13-2014, 12:55 PM
RE: Wire wound resistor - by morzh - 07-13-2014, 02:02 PM
RE: Wire wound resistor - by GarySP - 07-15-2014, 08:29 AM
RE: Wire wound resistor - by morzh - 07-15-2014, 08:48 AM
RE: Wire wound resistor - by fields 100 - 07-15-2014, 10:15 AM
RE: Wire wound resistor - by tom.seeger - 07-15-2014, 10:51 AM
RE: Wire wound resistor - by TV MAN - 07-19-2014, 09:16 AM
RE: Wire wound resistor - by codefox1 - 07-21-2014, 10:32 AM
New member
Philco 630csx power cord
New member
There are currently 4070 online users. [Complete List]
» 2 Member(s) | 4068 Guest(s)
