Philco "Ventilator" window fan
Hi
Have you looked here?
http://www.philcoradio.com/history/hist6.htm
http://www.philcoradio.com/history/othrphil.htm
I used to own one of these units. Wish I had kept it, mine was in excellent, working condition.
I do not know exactly when they were introduced, but as they use 1937-38 concentric tuning knobs for two of the three controls they probably date from around 1939-40, given Philco's divestiture into other appliance fields beginning in June 1938 at the start of the 1939 model year.
Philco "Ventilator" window fan - by Guest - 09-09-2008, 04:10 PM
Re: Philco "Ventilator" window fan - by Ron Ramirez - 09-09-2008, 05:33 PM
Re: Philco "Ventilator" window fan - by Guest - 09-09-2008, 10:48 PM
Re: Philco "Ventilator" window fan - by Guest - 09-12-2008, 06:28 PM
There are currently 10550 online users. [Complete List]
» 3 Member(s) | 10547 Guest(s)
