Wire wound resistor
Morzh,
I am aware of the formula, my concern was the cushion factor.You think two is good enough, even in case of some possible short? I am not sure what happened with it in the past, perhaps something nasty,as the insulation went off on one section and the wire looks discolored , overheated.
Wire wound resistor - by fields 100 - 07-11-2014, 08:52 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 09:16 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 10:01 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:11 PM
RE: Wire wound resistor - by Warren - 07-11-2014, 10:50 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:56 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 11:00 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:03 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:05 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:12 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:20 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:16 AM
RE: Wire wound resistor - by GarySP - 07-12-2014, 09:30 AM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:46 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:01 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 10:37 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:47 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 11:01 PM
RE: Wire wound resistor - by codefox1 - 07-13-2014, 12:55 PM
RE: Wire wound resistor - by morzh - 07-13-2014, 02:02 PM
RE: Wire wound resistor - by GarySP - 07-15-2014, 08:29 AM
RE: Wire wound resistor - by morzh - 07-15-2014, 08:48 AM
RE: Wire wound resistor - by fields 100 - 07-15-2014, 10:15 AM
RE: Wire wound resistor - by tom.seeger - 07-15-2014, 10:51 AM
RE: Wire wound resistor - by TV MAN - 07-19-2014, 09:16 AM
RE: Wire wound resistor - by codefox1 - 07-21-2014, 10:32 AM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4033 online users. [Complete List]
» 2 Member(s) | 4031 Guest(s)
