Wire wound resistor
It never had any insulation between the turns, just the spacing between the turns. The wire should have been wound tight enough so the turns will not shift. The thread covering was just for protection.
Its just like a wirewound pot, the wire is not insulated, and each turn is isolated from the next by the spacing.
Wire wound resistor - by fields 100 - 07-11-2014, 08:52 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 09:16 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 10:01 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:11 PM
RE: Wire wound resistor - by Warren - 07-11-2014, 10:50 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:56 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 11:00 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:03 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:05 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:12 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:20 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:16 AM
RE: Wire wound resistor - by GarySP - 07-12-2014, 09:30 AM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:46 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:01 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 10:37 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:47 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 11:01 PM
RE: Wire wound resistor - by codefox1 - 07-13-2014, 12:55 PM
RE: Wire wound resistor - by morzh - 07-13-2014, 02:02 PM
RE: Wire wound resistor - by GarySP - 07-15-2014, 08:29 AM
RE: Wire wound resistor - by morzh - 07-15-2014, 08:48 AM
RE: Wire wound resistor - by fields 100 - 07-15-2014, 10:15 AM
RE: Wire wound resistor - by tom.seeger - 07-15-2014, 10:51 AM
RE: Wire wound resistor - by TV MAN - 07-19-2014, 09:16 AM
RE: Wire wound resistor - by codefox1 - 07-21-2014, 10:32 AM
New member
Philco 630csx power cord
New member
There are currently 4061 online users. [Complete List]
» 1 Member(s) | 4060 Guest(s)
