Philco "Ventilator" window fan
Hi Ron,
Yes, the second link has a pic of one toward the bottom. The one at the thrift store looks just like it just not quite as nice. Do you have any idea if it's worth 85 bucks? They originally had it marked at 150.00 then went down to something like 105.00 and now down to 85.00. I found one forum that talked about two that were on Ebay (the posts were from 2003) and they kept talking about one selling for more than the other, but never said how much. I can't find anything at all that would give me an idea of what these things sell for. I'd hate to spend 85.00 and then find one on Ebay for half that.
TAB
Philco "Ventilator" window fan - by Guest - 09-09-2008, 04:10 PM
Re: Philco "Ventilator" window fan - by Guest - 09-09-2008, 10:48 PM
Re: Philco "Ventilator" window fan - by Guest - 09-12-2008, 06:28 PM
