37-116 and 118
Well,
have just return from the trip to Hartford area where I
1) picked up 37-116 (the one that is going to Ukraine) or $175, and
2) 118, the same one I was denied the sale of first.The price came out to be 160.
Photos later, I haven't eaten since I had breakfast 8am.
37-116 and 118 - by morzh - 07-12-2014, 09:37 PM
RE: 37-116 and 118 - by Phlogiston - 07-12-2014, 10:00 PM
RE: 37-116 and 118 - by morzh - 07-12-2014, 10:36 PM
RE: 37-116 and 118 - by RadioSvit - 07-14-2014, 12:24 PM
RE: 37-116 and 118 - by morzh - 07-14-2014, 12:26 PM
RE: 37-116 and 118 - by RadioSvit - 07-14-2014, 02:04 PM
RE: 37-116 and 118 - by morzh - 07-14-2014, 02:51 PM
RE: 37-116 and 118 - by morzh - 07-17-2014, 03:18 PM
There are currently 10270 online users. [Complete List]
» 3 Member(s) | 10267 Guest(s)
