Brunswick Panatrope with Radio S31
I would clean them, but be very careful about polishing them, particularly the dial escutcheon. In spite of what many think a lot of trim parts on old radios and phonographs were not supposed to bright metal to start with, they left the factory with a matte, an antiqued, or sometimes a blued finish. If that Brunswick were mine I would give that stuff a cleaning but leave it alone, it looks very nice as it is.
RE: Brunswick Panatrope with Radio S31 - by morzh - 07-11-2014, 05:14 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-13-2014, 08:46 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-14-2014, 10:37 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-16-2014, 10:45 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-16-2014, 12:21 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-17-2014, 12:51 PM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:39 AM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:55 AM
There are currently 3087 online users. [Complete List]
» 3 Member(s) | 3084 Guest(s)
