Philco speaker
Higher B+ voltage. Depending on your load the degree may vary.
Tubes will run hotter, agai, how much depends.
Might be still within specs, might be not.
However there are radios where the coil is only a load and not a filter. This will increase your rectifier current but will not increase B+. Those are mostly small AC-DC radios.
Philco speaker - by fields 100 - 07-13-2014, 07:33 AM
RE: Philco speaker - by morzh - 07-13-2014, 10:22 AM
RE: Philco speaker - by Steve Davis - 07-13-2014, 10:49 AM
RE: Philco speaker - by morzh - 07-13-2014, 11:10 AM
RE: Philco speaker - by Arran - 07-13-2014, 11:36 AM
RE: Philco speaker - by fields 100 - 07-13-2014, 12:33 PM
RE: Philco speaker - by fields 100 - 07-13-2014, 01:26 PM
RE: Philco speaker - by Arran - 07-13-2014, 01:33 PM
RE: Philco speaker - by morzh - 07-13-2014, 01:56 PM
RE: Philco speaker - by fields 100 - 07-13-2014, 03:44 PM
RE: Philco speaker - by morzh - 07-13-2014, 04:15 PM
RE: Philco speaker - by codefox1 - 07-13-2014, 05:25 PM
There are currently 5860 online users. [Complete List]
» 2 Member(s) | 5858 Guest(s)
